Captive Portal Question
Currently running 6.3.x ArubaOS and looking to go to 6.4.x ArubaOS wondered if there is anyway to have a Captive Portal for Guest access that will format the page based on the device connecting?  Currently it looks fine with a Windows or Mac based device, but using a Android or iPhone or such it presents a full site view.  Currently don't have Clear Pass as I'm know that would address that issue.
Re: Captive Portal Question
You would need to upload a dynamic template.
Tim Cappalli | Aruba Security
ClearPass is the only fix that I know of. Only need ClearPass for Guest?
Contributor I
Clearpass may be the only way to have a diffrent webpage for a device type, but I think the easier solution would be to get a mobile-savvy web dev to re-create your on-controller custom captive portal to be more adaptive to the screen width.
Modern web devs are able to create pages with simple HTML5/CSS that adapt very well to diffrent screen widths, so the page items would become more vertical when showing up on the mobile devices.
I'm not arguing against Clearpass, but it seems like a big expense if this is the only problem you are attempting to solve with it!
You can do a UDR based on the device fingerprint and then pointing the device to different role which will point the device to the right portal
Thank you
Victor Fabian
Lead Mobility Architect @WEI
