Captive Portal/Routing Issue
I am trying to setup a wireless service for external visitors. The plan is for them to access a standalone ADSL network (VLAN 10 - 192.168.214.0/24) via ClearPass captive portal. Our clearpass devices sit on our main internal network (VLAN 1 - 10.1.48.0/22) on which our Aruba controller has an L3 interface. Our aruba controller also has an L3 connection to the ADSL network.
The issue I am seeing is that traffic coming from VLAN 10 to the ClearPass servers is being dropped. I have added a route on our ClearPass appliances and can ping the ADSL interface of the controllers from them, if I try and ping from the controllers to the ClearPass Appliances with a source of VLAN 10, the packets appear to be dropped. Packet capture on the ClearPass appliances shows the ICMP packets coming in and being responded to but the ping shows no replies.
Am I missing anything obvious on the controllers/clearpass appliances to allow inter VLAN routing?
Thanks.
Re: Captive Portal/Routing Issue
Is your clearpass virtual or hardware ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Virtual.
Thanks.
You have two options:
- Make clearpass guest portal public (reachable via public dns)
- Use an NAT ACL to send https/http traffic to clearpass via the Controller
Internal IP (the only issue with this solution is that you only will be
able to reach clearpass guest portal via IP)
Thank you
Victor Fabian
Thanks Victor,
The second option is what we are trying to do but if the ClearPass servers cannot be pinged by the controller on the ADSL source then surely an ACL will not work either?
If you do a ping source vlan you will be able to
ping it
you will need to define the ip nat pool (so the traffic will go through the
controller internal IP)
ip NAT pool GUEST-NAT-IP
netdestination CLEARPASS-SERVER-DEST
host
ip access-list session CLEARPASS-NAT-ACL
user alias CLEARPASS-SERVER-DEST svc-http src-nat pool GUEST-NAT-IP
user alias CLEARPASS-SERVER-DEST svc-https src-nat pool GUEST-NAT-IP
user-role guest-logon
access-list session CLEARPASS-NAT-ACL position 3
access-list session captiveportal position 4
access-list session captiveportal position 5
Thank you
Victor Fabian
Victor thanks for this but as I siad in my original post, if I do a ping source vlan, I cannot ping it.
I will try the config you have sent though and see how I get on.
Can you share your routing config on the controller?
Thank you
Victor Fabian
