Contributor II
Re: Captive Portal and Master-Local redundancy
Hi aalap22,
The reason why I need to walk over different SSIDs is because I am testing this wireless system using my laptop.
In the actual usage, guest SSID must be used for guests or ipads, employee SSIDs must be used for laptops with 802.1X PEAP with Windows 2008 R2.
I will test more scenarios and if I would have new issue to ask, I will be back here.
Thank you very much for your support.
Regards,  Mike
