Captive Portal display problem with IE
I get a weird problem with Internet Explorer displaying captive portal for CP Guest. I'm using the galleria theme and when my client is redirected to https://123.456.789.012/guest/blablabla.php it's well working but when he's redirected to https://CLEARPASS.MYCOMPANY.COM/guest/blablabla.php, there is no "box" and the text is directly on the background picture. (please refer to attached pictures to have a better understand).
Once again, it's only happening with Internet Explorer and I can't found where this come from.
Re: Captive Portal display problem with IE
Please open a case with TAC.   You created your own skin (modified the galleria skin).  It could be a problem with that.  It is possible that the server certificate is not trusted by your client or the webpage is making references to something that is not on the page; it could be that.  It could be a combination of both or something else...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
