Occasional Contributor I
Captive Portal issue
I've just configured 4 AP105's. We have some trouble with the Internal authentication of the Captive Portal.
When I am connected and filled in my password, I can use the wireless network. But after a couple of minutes, I guess
10 I have to authenticate myself again. I've configured the Inactivity timeout to 3600 secs and the reauth interval to 12 hours. But I still have to authenticate myself every couple of minutes. Does anyone experience the same problem?
Greetings
Re: Captive Portal issue
Hello cjoseph,
Thanks for your quick reply. About the printscreen you posted, is that an interface of a controller? We do not have a controller.
I only can connect to the AP105 and cannot find anything about security.
Greetz
I see, you are using Aruba Instant.  I apologize.
Thanks for your help so far..
See attachment for printscreen.
So when my device losses the connection, I have to reauthenticate again. But when I look to the settings, the reauth interval is 12 hours and the inactivity time out is one hour.
But when I'm idle for like 20 minutes I have to authenticate again.
Can you send me "show ap tech-support-dump" and client mac address?
The mac address is:  7c:c5:37:3e:ad:43
I think it only happens with ios devices....
Can we also get output of "show clients debug"?
I do not have that option. Can I do this also in CLI?
Yes. This also needs to be done while that client is attached.
I can't connect with putty or telnet to the AP? Do I have to connect to the console port?
