Contributor I
Captive Portal question
Hi All,
If we set up a Captive Portal for guests on, for example vlan 99, and a number of guests connect to that guest network, is there a way to segment each guest off so they cannot see, and ping other users in that vlan?
Jamie.
Re: Captive Portal question
Enable deny inter user traffic in the VAP
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
