Contributor I
Captive Portal slow / timeout
I don't know if this should be posted here or in the security section, but here goes:
We have a school, which uses Captive Portal for authentication for all students.
The controller is a 3400 running 6.1.2.7
Whenever the students starts class, roughly at the same time, they all try to validate through CP.
We're talking about 2-300 simultaneous logins. The CP is either extremely slow or simply timing out.
I'm guessing the controller can't handle the load, so what are my options ?
I tried convincing them to switch to 802.1X for authentication, but apparently that's not an option...
Can I tweak the controller in any way, or should it be able to handle this amount of connections ?
Regards
Kevin
Re: Captive Portal slow / timeout
You should first consider increasing the number of supported connections:
(Aruba3600) #show web-server
Web Server Configuration
Parameter                                      Value
Cipher Suite Strength                          high
SSL/TLS Protocol Config                        sslv3 tlsv1
Switch Certificate                             default
Captive Portal Certificate                     default
Management user's WebUI access method          username/password
User session timeout <30-3600> (seconds)       900
Maximum supported concurrent clients <25-320>  25
Enable WebUI access on HTTPS port (443)        false
(Aruba3600) (Web Server Configuration) #?
captive-portal-cert     Certificate name configured under certificate
                        manager
ciphers                 Configure cipher suite strength. Default is high
mgmt-auth               Configure management user's WebUI access method,
                        either username/password authentication or
                        certificate authentication or both. Default is
no                      Delete Command
session-timeout         Configure user's WebUI session timeout <30-3600>
                        (seconds)
ssl-protocol            SSL/TLS Protocol Config
switch-cert             Certificate name configured under certificate
                        manager
web-https-port-443      Enable WebUI access on HTTPS port (443)
web-max-clients         Configure web servers' maximum supported concurrent
                        clients <25-320>
(Aruba3600) (Web Server Configuration) #web-max-clients
 In addition, you could:
- Consder upgrading the older code
- Moving some clients to 802.1x as a pilot to decrease the reliance on the captive portal
- Make sure you have "Drop Broadcast and Multicast" enabled on all of your Virtual APs
Colin Joseph
Aruba Customer Engineering
Contributor I
Thank you for the quick reply, Colin. I did NOT know about the web-max-clients command.
I increased it to 100, that should hopefully do the trick.
the Drop Broadcast and Multicast was already enabled.
Will let you know when i get a status back, if increasing web clients helped :)
Regards
Kevin
Kevin,
Increasing that number just deals with the web server only serving 25 clients at a time being the bottleneck.  There will be increased memory requirements on the controller as a result.  Please consider upgrading the code because there are hundreds of bug fixes between the code you are on to where we are today.
Colin Joseph
Contributor I
I will try to get the code updated ASAP.
BTW, any recommended code to put on it ? Looking for a stable release, doesnt have to be the latest and greatest. :)
6.1.3.7.
You could also get a recommendation from TAC depending on what you are doing, but 6.1.3.7 is the most conservative, up to date option.
Colin Joseph
Trusted Contributor I
Is there a command to find out how many clients are currently consuming a connection to captive portal?  I can do a show user-table essid SSID_name and look for all users with the guest-logon role, which I assume would give me what I'm looking for, right?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Contributor I
First day after upgrading controller and increasing number of concurrent sessions. Everything went smooth.
Thank you
/Kevin
