Regular Contributor I
Captive Portal with bridge mode RAP
I have been reading the KB on how to configure captive portal withe a remote AP and bridge ssid here.  It states the following item:
2) Guests users are placed in a private VLAN which is isolated from normal corporate users.  Private IP addresses are assigned by a DHCP server on the controller.
 Will this work if the controller is not supplying DHCP addresses?  I have a remote site connected via a point to point VPN.  The firewall at the remote site is acting as the DHCP server for all hosts on that network including the APs.  The APs are 135s configured as RAPs.
Re: Captive Portal with bridge mode RAP
From the same article - "Typically, a wireless SSID (virtual AP) used for guest access in a Remote AP (RAP) is configured in 'bridge' mode (traffic routed locally).  However, the Aruba captive portal is hosted on the controller only. Therefore, an user associated to an SSID in bridge mode (forwarding mode) will not be able to reach the captive portal pages hosted on the controller.  In order to get around this, the SSID must be set-up in 'split-tunnel' mode. "
I have no issue switching this to a split tunnel SSID, however; if the controller isn't handing out the DHCP addresses will it still work.
I see..
Unfortunately, no.  After the user gets an ip address with the local site, he needs to be able to route to the controller's login page to do anything (bring up the captive portal page, etc..
Any update on the AOS that allow's captive portal for bridge mode configured RAP SSID?
Thank you.
Ryan
Captive portal is not supported in bridge mode on controller-based APs.
Tim
Tim Cappalli | Aruba Security
