Captive portal VLAN/IP address then swap to alternate VLAN after successful logon
Is this possible...?
Simplified explanation.
Wireless user connected to Captive Portal and gets a 192.168.1.5 address - Vlan 3
Wireless user successfully logs onto system (via RADIUS) and gets transferred to Vlan 5 with IP address 172.16.0.5
Is this possible and how?
Thanks for any help
Steve
Re: Captive portal VLAN/IP address then swap to alternate VLAN after successful logon
Thanks for any help
Steve
Doing this via Captive Portal is difficult, because the main issue is that the client has to detect that the link is down to even attempt to get a different ip address.
One way to possibly do this is to have the initial VLAN with a DHCP server that provides 10-second leases, so that after authentication, the client can attempt to renew his lease on the new subnet after the VLAN change, but not all clients respond uniformly to short DHCP leases.
We have had a number of users have varying results with the method above, but most of them gave up and moved to 802.1x.  In 802.1x the device receives the VLAN after authenticaton, so that you can set the VLAN to whatever you want it to be.
Have any developments or improvements been made in this arena?  I would very much like to force a new IP address and VLAN change on a client device after Captive Portal authentication from a RADIUS server.
