Frequent Contributor I
Captive portal issue for wired users... For wireless its working fine. !!! HELP me.
Dear Concerned,
Captive portal working fine for wireless users (guest ssid) but for wired users its not. Port 4 is asigned Vlan 4 and same guest aaa-profile but its not working good. here are the snapshots. Kindly help me in this regard.
Frequent Contributor II
Re: Captive portal issue for wired users... For wireless its working fine. !!! HELP me.
Have you set the port as Untrusted?
This is required for the Wired Captive Portal to work as it should..
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Yes exacrtly,  i have didnt configured the port as untrusted. After configured it untrusted, its working fine now.
One thing i want to know , after selecting untrusted its wroking, why it not works with trusted  port?
It was a great day with you..  You have solved 3problems of mine today.. Hatss off to you.
Great dude :smileyvery-happy:
