Frequent Contributor I
Captive portal login page url returns to default after setting captive portal profile.
I am setting up a captove portal with clearpass and whenever I set the following values on the controller (shown in the picture), one of them always return to default. What am I doing wrong?
Thanks.
Re: Captive portal login page url returns to default after setting captive portal profile.
You shouldn't need to do any captive portal customization on the controller
itself. What are you changing in the customize login config?
Tim Cappalli | Aruba Security
The "Customize Login Page" portion only shows you a list of profiles and allows you to cycle through them using the drop down. When you return to the page, it always shows you the default profile by default. Your other settings should not be affected by that.
