Occasional Contributor I
Captiveportal GPP not working with IE9
Captiveportal using the GPP WebUI is working with Internet Explorer v.8.0.7600.16385 and Mozilla Firefox v.9.0.1 the functions are fine. However, in Internet Explorer v.9.0.8112.16421 – cannot create guest accounts via GPP. IEv9 refreshes every sec making it impossible to create a user, modify, and even logout. Has anyone else had this problem, or similar issue?
Re: Captiveportal GPP not working with IE9
We can't use IE9 with our captive portal either.
MVP
Yea, can conform the same issues here - on AOS 6.1.2.7. You should open a support case for it :)
..John
Regards
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
MVP
This is still a problem in 6.1.3.4 ..
Regards
John Solberg
