Contributor I
Ceiling mounting kit for Aruba-225 access points.
Folks,
We have some challenges with getting the final design for our ceiling and I am in some doubts if to go with the "AP-220-MNT-C2" or the "AP-220-MNT-W2W" mount kit. We are going ahead with the "2AP-220-MNT-W2W" kit to be on the safer side.
I just wanted to know if anyone has seen any challlenges with getting these mounted on the ceiling.
N.
Aruba
Re: Ceiling mounting kit for Aruba-225 access points.
Can you elaborate on what the ceiling material is?
The C2 mount is for ceiling tile grids while the W2 is for surface mounting.
AMFX | ACCX | ACDX | ACMX
Contributor I
This is a mix of tiles and flat surface with plaster of paris.
N.
