Contributor I
Centralized DHCP L3 - IAP
 I'm configuring the Centralized DHCP L3 on an IAP scenario, due to I'm getting IPs for the clients from an external DHCP server, but we use a proxy to filter the traffic. I was checking that on the proxy I just get the IP of the AP (It's natting) instead of the user so it cannot do it's job.
Is there a way to send the traffic without nat with the AP's IP?
Regular Contributor I
Re: Centralized DHCP L3 - IAP
Which iap firmware?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Contributor I
6.5.1.0
