Frequent Contributor I
Centralized License for Aruba 7210 and 7030
If my customer environment only have 2 units of Aruba 7210 or Aruba 7030, can it configure centralized license? Of cause, 2 units of Aruba 7210 or Aruba 7030 will be configure as HA.
Re: Centralized License for Aruba 7210 and 7030
Yes. If they're master/local, just click the enable checkbox on the master
under centralized licensing and then save config.
Tim Cappalli | Aruba Security
