Contributor II
Centralized Licensing questions for 6.3
Just trying to make sure before I license the wrong controller...
Already have 16 controllers, master/local setup with master redundancy.....licenses installed old fashioned way, each controller getting its own set.
I have two brand new 7210 controllers and I bought 64 licenses for each one....
SO.....
I should install the licenses on the master licensing server.....and then the controllers will pull as many as they need?  Meaning those 128 AP license count could get splt up 5 here, and 15 over there, and another 2 over there, and 80 over there?
OR
If I use 1 ap on the controller it assumes the entire 64 ap license?
Re: Centralized Licensing questions for 6.3
This is the way it will work
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
That's what I thought and after reading your post I tested it out and WOW!
Now I have more unused AP licenses than I know what to do with......
