Contributor I
Certificate Issue with iOS
Hi everyone
Here is the issue...
We want to put this certificate on the Captive Portal, we create de CSR on the controller and go to VeriSign to get  a Cerrtificate
We upload it as PEM, server cert, but the issue comes when we try to connect an iPad, iPhone, iPod or Android devices, on Laptops it goes ok, but on that devices for example iOS we get this.
And we do not want to pop up this message on this devices.
Can you help me with that.
thanks a lot.
Contributor II
Re: Certificate Issue with iOS
I've been told they are working on a certificate that will come part of a future firmware update.
It's been an issue for me since day one.
Glad to know it's being addressed, but it's now be 7 months that I've been waiting for a fix...
Ness wrote:
Hi everyone
thanks a lot.
Most likely you have to allow http traffic to the OSCP server of your CA.  Please see the knowledgebase post here:  http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=643
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Chris,
Aruba has a built-in proof of concept certificate that should only be used for proof of concepts.  When deployed, customers are highly encouraged to replace this to ensure their security.  There is no certificate that can be deployed that will replace something that you need to purchase to secure your network.  There is nothing to address with regards to proof of concept certificates on the controller.
Contributor II
Hi Colin:
My response was a little quick as this was on the controller forum (didn't note that when posting).
Really, my response belongs to the IAP line and captive portal.
Thanks for clarifying, Chris.
