Contributor I
Certificate based authentication with controller without external RADIUS server
Hello!
I am trying to make a network with controller and access point, and I want the Users to authenticate to the wireless network with certificates (no usernam/password). Can it be done without an external RADIUS server? Can the controller authenticate with internal database and certificates? And if so, how?
Thx!
Frequent Contributor I
Re: Certificate based authentication with controller without external RADIUS server
NO.
You need radius server for this.
- Yopianus Linga-
Yes, you can configure EAP termination with EAP-TLS. Take a look at the user guide.
Tim Cappalli | Aruba Security
Hi Cappali, I'm a bit confused with the "yes" statement.
Did you mean yes-approving my answer or, yes-can auth using cert without radius ?  :D
from guide :
EAP-TLS requires that you import server and certification authority (CA) certificates onto the controller(see “Configuring and Using Certificates with AAA FastConnect” ). The client certificate is verified on the controller(the client certificate must be signed by a known CA) before the user name is checked on the authentication server.
-Yopianus Linga-
A RADIUS server is not required but is generally recommended.
