Certificate error for web Ui management
HI all,
I have just start to play with a 3400, it has firewall licence and ap licence on it. The od is I know it is old, how can i update it? also there are ony way to disable https in lab environment?
Thank you all
Re: Certificate error for web Ui management
Most recent ArubaOS version for the 3400 is version That version is available on the Aruba support website and requires an active support contract to download.
On the certificate, check in this post: https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Controllers/ta-p/275809 how to put an alternative certificate in your controller. I'm not aware of a possibility to disable HTTPS for the web management, and for lab use, most people I know just ignore the certificate warning. If you run into the 'revoked certificate' problem, check the mentioned post to put in a self-signed certificate.
