Certificate issue Aruba 650 controller
The controller is not allowing us to login,  we cannot  access to controller´s  web interface and create a guest-user with a managment user ( guest-provisioning role).
The browser show us a certificate error "This certificate has expired or is not yet valid"
The firmware  was updated recently from  6.1 to  6.4.4.6  version to solve the issue but the new firmware doesn´t solve the issue.
Could you help me to solve the issue?
Thanks.
Regards.
Ivan.
Re: Certificate issue Aruba 650 controller
Did you set the time on the controller or your management station?
Please upgrade to 6.4.4.10 or newer. The version 6.4.4.8 has a revoked (and probably expired) certificate built in.
Starting 6.4.4.10, the controller will generate a self-signed certificate. Which will show an untrusted (instead of expired) certificate warning.
To get rid of the certificate warnings, you will need to install a trusted certificate. Check this post on the background on what happened between 6.4.4.9 and 6.4.4.10. That can be done on 6.4.4.8 as well.
If you still have a valid support contract, you can get 6.4.4.15 from the Aruba Support website.
