Contributor I
We have an expired cert on our controller.  I generated a new CSR from thawte and installed it, do I need to delete the expired cert from the controller to have it use the new one?  Or will it use the new one automataically?
Re: Certificates
we need to map the new cert to the web server or to the dot1x auth profile manually.
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
