Frequent Contributor II
Certs question
Afternoon all,  am swapping a couple of old controllers for 2 x new.  Customer uses 802.1x local termination, with officialy generated certs, 1 for client and 1 for controller to Radius.
Can I pull these off and just put on new controllers ?
Cheers
ACMA/ACMP
Re: Certs question
If you have the private key, yes.
Tim
Tim Cappalli | Aruba Security
Re: Certs question
Tim, thanks, as you may guess i'm no certs expert, so this is possible ?
Ta
ACMA/ACMP
Re: Certs question
If you have the private key, yes. If you don't have the private key, you'll need to request a new cert.
