Occasional Contributor I
Change Air Monitor mode to AP mode
Hi everyone,
I have an 228 AP is provisioned with 7210 Controller running 6.5.1.4 OS.
My Ap only working as Air Monitors mode and i I couldn't find the way to change it from Air Monitor mode to AP mode.
Any one can show me step by step to fix this issue ?
Thanks for help.
Frequent Contributor I
Re: Change Air Monitor mode to AP mode
Is AP license install?
Thank you,
Ratchapas S.
The AP appears to have been provisioned in the "default" ap-group, which I suspect is using AM-Mode in the Radio profiles. You will need to either change the AP mode within Radio Profiles or re-provision the AP to a different ap-group where the AP's are configured to use AP mode.
http://community.arubanetworks.com/t5/Wireless-Access/How-to-change-am-mode-to-ap-mode/td-p/17526
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Hi zalion,
You're right. My 228 AP have been provisioned in the "default" ap-group, but i have a  question that why after provision, only 228 model have been changed to Air Monitor while 325 model still is AP mode
Thanks for help.
Are they both in the default ap-group? What is the regulatory domain of of the AP228 set on the default group? Are you able to provide the output of the below?
#show ap database
#show log all | include XXXX (wired MAC of AP)
ACMA, ACMP, ACSA
Use this command for check compatible of AP model "show ap allowed-channels country-code <country-code> ap-type 228"
Thank you,
Ratchapas S.
Hi Zalion,
Sorry for lately reply,
They both in the default group. I  don't clear about "regulatory domain" but hence is output:
#show ap database
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
20:a6:cd:cc:45:7e default 325 172.16.0.103 Up 15m:39s 2I 172.16.0.254 0.0.0.0
b4:5d:50:c8:d2:2c default 228 172.16.0.104 Up 17m:24s 2 172.16.0.254 0.0.0.0
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
i = Indoor; o = Outdoor
M = Mesh node; Y = Mesh Recovery
Total APs:2
#show log all | include b4:5d:50:c8:d2:2c
Jan 16 11:31:20 nanny[2836]: <303022> <WARN> |AP b4:5d:50:c8:d2:2c@172.16.0.104 nanny| Reboot Reason: AP rebooted Wed Dec 31 16:05:19 PST 1969; DHCP timed out
Jan 16 11:34:16 KERNEL(b4:5d:50:c8:d2:2c@172.16.0.104): [ 307.768435] enabling the USB interface
Jan 16 11:35:12 stm[4091]: <402000> <4091> <WARN> |stm| AP b4:5d:50:c8:d2:2c radio 0: No valid channels; entering air monitor mode.
Jan 16 11:35:12 stm[4091]: <402000> <4091> <WARN> |stm| AP b4:5d:50:c8:d2:2c radio 1: No valid channels; entering air monitor mode.
#show log all | include 20:a6:cd:cc:45:7e
Jan 16 11:31:46 nanny[2222]: <303022> <WARN> |AP 20:a6:cd:cc:45:7e@172.16.0.103 nanny| Reboot Reason: AP rebooted Wed Dec 31 16:05:04 PST 1969; DHCP timed out
Jan 16 11:33:35 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 160.309653] Disabling USB power
Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976038] Enabling USB power
Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976069] Enabling eth1 due to power change [power profile 1]
Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976601] Resetting spectral chainmask to Rx chainmask
Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976694] Resetting spectral chainmask to Rx chainmask
Thanks for help
Thanks, if you don’t know the regulatory domain of the AP (you’ll be able to find this under the sap-group) could you let us know the country where the AP is installed?
Please also run the following command
show ap allowed-channels country-code ap-type 325
Sent from my iPhone
ACMA, ACMP, ACSA
Hi Zalion,
This is output:
#show ap allowed-channels country-code VN ap-type 228
Allowed Channels for AP Type 228 Country Code "VN" Country "Vietnam"
PHY Type Allowed Channels
802.11g (indoor) None
802.11a (indoor) None
802.11g (outdoor) None
802.11a (outdoor) None
802.11g 40MHz (indoor) None
802.11a 40MHz (indoor) None
802.11g 40MHz (outdoor) None
802.11a 40MHz (outdoor) None
802.11a 80MHz (indoor) None
802.11a 80MHz (outdoor) None
802.11a (DFS) None
show ap allowed-channels country-code VN ap-type 325
Allowed Channels for AP Type 325 Country Code "VN" Country "Vietnam"
802.11g (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
802.11a (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
802.11g (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
802.11a (outdoor) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
802.11g 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
802.11a 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
802.11g 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
802.11a 40MHz (outdoor) 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
802.11a 80MHz (indoor) 36-48 52-64 100-112 116-128 149-161
802.11a 80MHz (outdoor) 52-64 100-112 116-128 149-161
802.11a (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
==> Refer the output, Does my 228 ap not allowed with any channel and can't use ?
Many thanks
Can you confirm which DRT you are running? It seems that the 228 in Vietnam is supported from DRT 1.0_61955 onwards.
Sent from my iPhone
ACMA, ACMP, ACSA
