Contributor I
Changed controller IP and now radius doesn't work
I changed my controller IP to a different vlan/interface.  I rebooted the controller.  I also changed the NAS IP to be the new IP/VLAN, and added a new NPS client on the Windows NPS Server, but authentication fails.  I retyped the passwords 3 times now.  I deleted the new NPS client, and editec the old client with the updated controller IP.  I have tried deleting all NPS clients and recreating them.
Still authentication test fails.
Re: Changed controller IP and now radius doesn't work
Do ?show ip radius source-interface?. Is that the IP you are expecting you RADIUS server to see? If not, you can change it using the ?ip radius source-interface vlan x? command from config mode.
Contributor I
That output is the new controller IP/VLAN, so that looks good.
When you are trying to use the aaa test command, what output are you getting - failed or timed out?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor I
Authentication Failed
Good!  That means that the controller and RADIUS server are correct.  The user/credentials failed.
Can you try MSCHAPv2 vs PAP?  That may be the issue.
Seth R. Fiermonti
Email: seth@hpe.com
