Regular Contributor I
Changing Licensing Management System Information
I'm moving a controller to a new location and want to update the related information field in the online Licensing Management System but I do not see any way to edit an existing entry.
Re: Changing Licensing Management System Information
But you could call TAC and they should be able to help you that.
Thank you
Victor Fabian
Lead Mobility Architect
Regular Contributor II
Are you trying to update/change the System Location field?
You can do that under Utilities.
Thanks Cole,
FYI if anyone else is using IE10 and can't access the tabs like I had, use Chrome.
