Changing aruba-master dns entry
I have our VRRP instance running and now need to point my APs to the VIP address rather than a single controller.  I was going to do this by changing our DNS entry for aruba-master to point to the VIP address.
When I make this change will the APs immediatly see this change or will they, on their own time, see the change and reassoc to the new ip?
Re: Changing aruba-master dns entry
The APs look for aruba-master as part of the boot process. Once they are up, they won't lookup aruba-master until a bootstrap/reboot.
Tim Cappalli | Aruba Security
