Changing default Virtual Controller DHCP range
I just got in 4 Aruba IAP-105s that I am setting up for the first time.  The Aruba network is giving out 192.168.11.X addresses with a 192.168.11.1 default gateway which doesn't match the IP I've assigned the APs or the subnetting of my network.  Where can I find the option to change the default DHCP range?
MVP
Re: Changing default Virtual Controller DHCP range
[ Edited ]
Hi
Good night.
in InstantAP - u can get a DHCP from a local vlan (connected to the virtual control unit)
or get a DHCP assigen by the virutal controler itself (it cannot be modifed or changed)
the   Guest functionlality is designed to use the controller assigned IP addressing and the client traffic will be NAT'ed to the virtual controller address
MVP
[ Edited ]
Also
Download the attached PDF - it will give u a quick and short guide on how to config.
This guide contain all the needed info in order to deploy guest + enteprise wlans with InstatAP in just a few min, written by:
kevinklee
MVP
If you are referring that you are doing virtual controller assigment instead static vlan... then you change it here..
Alternetworks Corp
