Changing from Master-Local to Master-Master CP doesn't work on the backup master
Hello Everyone!
So I am changing my current configuration to a Primary Master -Backup Master model  and the Captive Portal page doesn’t work when it fail it over to the back up. I realize the that the VLAN interface on the backup has a different IP and that is why it ti broken.
What is the best way to set this up? I am probably missing something obvious.
You comments would be appreciated!
C E
Re: Changing from Master-Local to Master-Master CP doesn't work on the backup master
You need to set the ip cp-redirect-address to the ip address of the VLAN interface on that local controller:
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-ip-cp-redirect-address/td-p/236
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
