Contributor I
Channel Changes and Channel utilization
In my case, I discover that most of the AP managed have high utilization, more on 2.4GHz (>70%) radio ofcourse..while investigating, I found that there are groups of AP which use same channel and located really close to each other..
Based on the wireless nature, I assume it will cause a broadcast storming and utilize the channel later on..but my concern is, why does not ARM change the channel..?
If it is because of configuration, where can I configure the ARM..? or what is actually the criteria for channel change to occur..
When same channel is used, there should be a drawback rigth..?
When utilization is high, will it effect the user experience..?
Mohamad Syafiqul Haziq,
System Engineer, Mesiniaga Berhad.
Re: Channel Changes and Channel utilization
What type of APs do you have ?
The end result depends on a lot of things :
- How much the APs can hear each other based on proximity and power levels
- How's ARM configured ?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
