Occasional Contributor I
Channel & enable data rate(MCS)
Please let me know '+', 'E' with channel.
Does it means "40 MHz" and "80 MHz" ?
(For example, 44+ means Channel 46(40 MHz), 52E means Channel 58(80 MHz))
Also, Is it enable to control data rate and mode(b, g, n, ac)?
Re: Channel & enable data rate(MCS)
JJ Lee wrote:
Your statement is correct.  Please see the document here for more details:  http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/802-11ac-Basics-and-FAQ/ta-p/20024
