Hi guys,
After implementing a cluster of Instant APs, I can see the following output:
I can see that all the clients connected to the 5GHz band are using channel bonding, since all the 5GHz channels used have the "E" or "+" suffix. Also, DFS channels are being used by default (unlike with controllers), since channels 52+, 100E and 116E are being used.
My first concern is, what happens if a 5GHz client with no support of channel bonding wants to associate to AP Sala7-2P (which is using channel 116E)? Same applies to every AP, since all of them are using channel bonding. Will the AP stop channel bonding and start using 20 MHz channels in the 5GHz band?
