Contributor I
Channel for AP103H and AP205 in HK
Our AP205 and AP103H go to AM mode.
When we show the channel. There is no channels (please refer to the attached file) for HK.
Please advise.
Samantha
Re: Channel for AP103H and AP205 in HK
Samantha,
What version of Instant software are you using?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
Dear Colin,
Our software is
(DS219CR01) #show ver
ArubaOS (MODEL: Aruba7030), Version 6.4.1.0
Website: http://www.arubanetworks.com
Copyright (c) 2002-2014, Aruba Networks, Inc.
Compiled on 2014-06-12 at 03:48:45 PDT (build 44233) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.2.0 (build 43722)
Built: 2014-05-13 10:06:50
Built by: p4build@re_client_43722
Samantha
samsam,
According to the release notes, you need to be on at least 6.4.2.1.  Please try upgrading to that version of ArubaOS.
Contributor I
Thanks a lot. There are channels for HK now.
