Occasional Contributor I
Channels supported by clients?
Is there a list/database of devices and the channels they support?
The reason I ask is that when making a channel plan, you need to take into consideration which channels are supported by the clients which will connect to it, for example, as I understand, in the USA channel 13 is not supported which means that clients also don't support it. If you have a network with Channel 13 in Europe, where the devices support it, a device from USA won't be see this AP on channel 13.
Same thing for the 5GHz band?
Re: Channels supported by clients?
It is probably easier if you figure out what clients you have, first.  If you have good density, the channel 13 thing is not an issue, really.  If you feel that strongly about it, you can eliminate channel 13 from the regulatory domain profile;
Colin Joseph
Aruba Customer Engineering
