Cisco 3750E Stack & Aruba 3400 Controller -- Port Channel Issue
Hello. The issue I am having is when I put one port of an Aruba controller in a Port channel I can't ping the default gateway. I only have this one port connected to the switch to try and rule out any other issues. Once I take the one port out of the Aruba port channel and put it just pure trunked I can ping the default gateway. My laptop on the same network can ping the controller in both scenarios. Also once I do this, I lose all remote access to the controller (web/ssh).
Cisco Port Config:
description Wireless Controller Port 1
switchport trunk encapsulation dot1q
switchport mode trunk
switchport nonegotiate
flowcontrol receive on
channel-group 30 mode on
interface Port-channel30
description Port Channel for Wireless Controller
spanning-tree portfast trunk
Aruba Side
interface gigabitethernet 1/1
description "GE1/1" trusted trusted vlan 1-4094
switchport trunk allowed vlan 1-4094
interface port-channel 0
add gigabitethernet 1/1
trusted vlan 1-4093
switchport trunk native vlan 70
ArubaOS 6.1.3.1
Re: Cisco 3750E Stack & Aruba 3400 Controller -- Port Channel Issue
 Try this on the Aruba Controller:
trusted.
Adding the trusted to the port channel now allowes me to remotely get into the controller, but I still can't ping the default gateway.
What is the default gateway?  Can you see it in your ARP table?
Nothing in arp.
Are you pinging From:
A client on the LAN, the controller or a router?
What device is the default gateway in this situation?
When in port channel:
  Pinging from Cisco switch to controller = fail
  Pinging from controller to cisco switch = fail.
  Pinging from laptop in same subnet = is good
When in plain trunked port:
  everything works.
Cisco switch provides the default gateway.
  everything works.
Can you clear the ARP table on all devices and try again?
A suggestion.
On the Cisco side:
interface xxxxx
 channel-protocol lacp
 channel-group 30 mode active
On the Aruba side:
 lacp group 0 mode passive
Still no luck.  I have clear arp tables on both devices and no avail.
I did change everything over to LACP and still no luck.
description "GE1/1"
trusted
trusted vlan 1-4094
speed 1000
duplex full
interface port-channel 7
trusted
trusted vlan 1-4094
switchport access vlan 70
Cisco:
sh eth sum
30     Po30(SU)        LACP      Gi1/0/39(P)
interface GigabitEthernet1/0/39
speed 1000
duplex full
end
