We have recently migrated a set of our Aruba 3400 Controllers from traditional Rtr/Switch topology to Cisco ACI. The last couple months we have noticed off occurrences dealing with Packet Loss from End Users either connected to APs or RAPs. We have reloaded the 3400 Controllers a couple times and this seems to resolve the issue but only temporarily. I am not 100% convinced we have the ACI Interfaces to Aruba Interfaces configured correctly which is causing our problems.
I also want to point out I have 2 Aruba 3400s at this location configured the same with the exception of Interface IPs.
Aruba Configuration:
SETUP: Master / Local Configuration
MODEL: Aruba3400
VERSION: 6.3.1.14
ROLE: Local Controller
vlan 30 - All Wireless User Subnet (AP & RAP)
vlan 60 - Management Network
vlan 168 - Guest Wireless User Subnet
vlan 567 - Mobile User Subnet (MDM)
vlan 966 - Public Network
interface gigabitethernet 1/0
description "GE1/0"
trusted
trusted vlan 1-4094
switchport mode trunk
switchport access vlan 30
switchport trunk allowed vlan 30,60,168,567
interface gigabitethernet 1/2
description "GE1/2"
trusted
trusted vlan 1-4094
switchport access vlan 966
interface vlan 60
ip address xx.xx.xx.95 255.255.255.0
no ip routing
bcmc-optimization
interface vlan 30
no ip routing
bcmc-optimization
interface vlan 966
ip address xx.xx.xx.53 255.255.255.0
no ip routing
bcmc-optimization
interface vlan 567
no ip routing
bcmc-optimization
interface vlan 168
no ip routing
bcmc-optimization
GE 1/0 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 00:0B:86:6F:26:0D (bia 00:0B:86:6F:26:0D)
Description: GE1/0 (RJ45 Connector)
Encapsulation ARPA, loopback not set
Configured: Duplex ( AUTO ), speed ( AUTO )
Negotiated: Duplex (Full), speed (1000 Mbps)
MTU 1500 bytes, BW is 1000 Mbit
Last clearing of "show interface" counters 23 day 12 hr 40 min 39 sec
link status last changed 23 day 12 hr 36 min 48 sec
1744773237 packets input, 1376375032868 bytes
Received 18338884 broadcasts, 0 runts, 0 giants, 0 throttles
0 input error bytes, 0 CRC, 0 frame
15641428 multicast, 1726434353 unicast
1683401939 packets output, 1352014369653 bytes
0 output errors bytes, 0 deferred
0 collisions, 0 late collisions, 0 throttles
CISCO ACI Configuration
VERSION - 12.0.2g
All Vlans are setup one to one with End Point Groups (EPG) and Bridge Domains (BD). All EPGs are in a single VRF, Domain, Application Profile, and Tenant.
ACI Interface to Controller Configuration
EPG30/BD30
L2 Unknown Unicast = Flood
L3 Unknown Multicast = Flood
Multi Destination Flooding = Flood in BD
ARP Flooding = Flood
Encapsulation = Vlan-30
No Contracts Used
Ethernet1/7 is up
admin state is up, Dedicated Interface
Port description is CORSTLSDR3400-01:Fa1/0 INT
Hardware: 1000/10000/auto Ethernet, address: f8c2.88b5.6a3f (bia f8c2.88b5.6a3f)
MTU 9000 bytes, BW 1000000 Kbit, DLY 1 usec
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, medium is broadcast
Port mode is trunk
full-duplex, 1000 Mb/s, media type is 1G
Beacon is turned off
Auto-Negotiation is turned on
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped 03w23d
Last clearing of "show interface" counters 00:47:05
4 interface resets
30 seconds input rate 8151544 bits/sec, 1117 packets/sec
30 seconds output rate 7811080 bits/sec, 1122 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 14173696 bps, 1810 pps; output rate 14368184 bps, 1851 pps
RX
6524296 unicast packets 4110 multicast packets 10048 broadcast packets
6538454 input packets 5751643352 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
6283754 unicast packets 21733 multicast packets 3047 broadcast packets
6308534 output packets 5677787433 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Could the way we have ACI configured be causing an issue with the trunk to the Aruba Controller?
