Cisco, PVST+, and Mobility Controllers with Redundant Connections
What is the recommened configuration for connecting an Aruba 3600 series controller with redundant connections to two Cisco 6509 switches?  I have seen that prior to 6.x the controllers did not support PVST+ and to disable spanning tree and let the Cisco switches manage the spanning tree infrastructure.  Has anything changed in this area?
Mike
Frequent Contributor II
Re: Cisco, PVST+, and Mobility Controllers with Redundant Connections
In 6.x you can use PVST+.
