Occasional Contributor I
Clean-Up Flash
Hello -
We are struggling to upgrade a controller - we are out of space in flash.
I can delete files from DISK but I cannot see anyway to clean up Flash - show storage is the best I can find but are there CLI or web interface commands to get into flash to clean it up? Do we just keep rebooting the device untill flash frees up some space?
Need to get this upgrade done to get my controllers online
Re: Clean-Up Flash
how much space you got on flash?
Can you please do
show memory
And also
Show storage
To see the output?
Alternetworks Corp
Re: Clean-Up Flash
show memory
Memory (Kb): total: 387692, used: 288396, free: 99296
show storage
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock11 156.0M 128.8M 27.2M 83% /flash
none 300.0M 1.7M 298.3M 1% /tmp
/dev/mtdblock9 50.0M 24.6M 25.4M 49% /mnt/img0
/dev/mtdblock10 50.0M 24.3M 25.7M 49% /mnt/img1
Re: Clean-Up Flash
Okay
do a show boot
and it will show you the configuration file is using right now....
You should be able to delete old coniguration files, at least just delete the older ones...
As reference for you i remenber i read this a while ago... i searched in the airheads forum for you as reference.
Here is it
http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Which-files-can-I-delete-in-my-A200/td-p/11046
Hope this helps you
Alternetworks Corp
Re: Clean-Up Flash
Also take in mind that
You should have at least 40 MB of free memory available for an upgrade using the CLI, or at least 60 MB of free memory available for an upgrade using the WebUI.
Cheers
Carlos
Alternetworks Corp
Re: Clean-Up Flash
Where you able to delete old configuration files and do the upgrade?
Alternetworks Corp
