Frequent Contributor II
ClearPass Policy Manager 6.4 Quick Start Guide
Tech Note for installing CPPM 6.4 states:
10.When you see the banner on the virtual machine console, you can log in by following the instructions in the ClearPass Policy Manager Quick Start Guide.
I'm unable to locate a ClearPass Policy Manager 6.4 Quick Start Guide - anyone know where this can be found?
Re: ClearPass Policy Manager 6.4 Quick Start Guide
Aruba
I don't see one for 6.4 specifically, but the 6.2 Quick Start Guide can be found here.   Also, the 6.4 Getting Started Guide should have the information you need.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11740
The Getting Started Guide:
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14791
AMFX | ACCX | ACDX | ACMX
Thanks, Tim. I had taken a look at this doc but couldn't seem to find what they were referring to in there. I'll peruse it a little closer.
Aruba
Check Chapter 2:  Accessing Policy Manager.
Thank you - I took a look at this one but it seemed to be specific to the hardware applicance rather than to VM installation. Safe to say there's no significant difference?
Aruba
The Quick Start Guide has been rebranded the Gettting Started Guide.  They should contain the same  (updated) information.
Correct. The CLI and UI are identical.
Tim Cappalli | Aruba Security
Aruba
The first chapter is more specific to the appliance; Chapter 2 on is more generic.
Thank you.
