Contributor II
Clearpass Interdevice Connectivity
We are currently looking into purchasing Clearpass as our current BYOD solution is nearing end of life.
One of our main requirements is allowing devices that are registered to the same user have the ability to communicate with one another while preventing other devices registered to different people on the same network communicating the other persons devices.
Can anyone tell me if this can be done please?
Many thanks
Shaun
Re: Clearpass Interdevice Connectivity
This would not be a function of a network policy server. This would be
enforced at the network device level (switch, controller, firewall, etc).
Tim Cappalli | Aruba Security TME
