Contributor I
Clearpass and Instant APs in remote locations:
Hi All
Is there any issues with having Instant AP in a remote locations and authenticated/Guest managed/Onboarded by Clearpass using 1 or 2 MB WAN links.
I have 9 sites with about 4 x Instant APs and Clearpass and Airwave in central location.
Harry
Re: Clearpass and Instant APs in remote locations:
Do you know what's the delay I'm "ms" between sites ?
If your end to end delay is under 400 ms you should be ok
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
Thanks Victor i will check this
