Client Match, Band Steering & Load Balancing
  • 1.  Client Match, Band Steering & Load Balancing
    Posted Nov 24, 2015 07:20 AM
    Hi
    We originally had band steering set and disabled load balancing as was recommending 5 years ago, we also have  N off for 2.4Ghz.
    Now we have upgraded the OS to 6.4 should we be using Client Match? Should I now turn off band steering and enable load balancing or will Client Match overide these settings?
    Should I now allow N for 2.4Ghz?
    Many thanks
  • 2.  RE: Client Match, Band Steering & Load Balancing
    Posted Nov 24, 2015 07:45 AM
    ClientMatch will override the individual knobs (Band Steering, client LB , sticky devices)
    Why disable N on 2.4 , essentially that gives your N 2.4 devices a boost on the data rates/speeds that N introduced
  • 3.  RE: Client Match, Band Steering & Load Balancing
    Posted Nov 24, 2015 08:30 AM
    Hi
    I am not sure why it was setup that way originally?
    Profiles - RF Management - 802.11g radio - N-off - ARM - single-band - a-only
    Should i remove N-off?
  • 4.  RE: Client Match, Band Steering & Load Balancing
    Posted Nov 24, 2015 12:26 PM
    This is enabled in the HT SSID Profile and Radio Profile
  • 5.  RE: Client Match, Band Steering & Load Balancing
    Posted Nov 24, 2015 12:07 PM
    What kind of devices are you using? How many clients are in your network with how many access points?
  • 6.  RE: Client Match, Band Steering & Load Balancing
    Posted Nov 25, 2015 03:51 AM
    Hi
    We have laptops, Tablets, Ipads and Iphones.
    Laptops connect to the domain via VPN, other devices including guests connect through captive portal.
    145 WAP's, can be around 250 devices.
