Client Match settings in VHD environments
The Very High Density VRD recommends a number of Client-Match settings made inside the ARM profile.  You likely have two separate ARM profiles (A and G) in order to have different max power settings for each of those radios.
The question is, should the same Client-Match (and other VHD settings) be applied to both ARM profiles, even though some of those settings are G specific?
