Frequent Contributor II
Client Signal strength in controller dashboard
Aruba controller dashboard i got the client speed, max. speed, SNR, good put, band, radio, AP name, AP mac, client mac etc...
But which parameter consider for client signal strength on the dashboard?
Or is there any application to get the all those details.
Re: Client Signal strength in controller dashboard
That would be the SNR http://en.m.wikipedia.org/wiki/Signal-to-noise_ratio
Colin Joseph
Aruba Customer Engineering
