Client communication between APs
This thread has been viewed 35 times
  • 1.  Client communication between APs
    Posted Sep 12, 2018 08:32 PM
    We have a setup with aruba wireless access points. We are trying to use iPads and connect with wireless Brother printers. It works great as long as they are connected to the same access point, but if the iPad is on a different access point than the brother than it will not find it. I cannot ping devices across different APs either. I think theres a few other issues in the building also related to this.
    We're running an Aruba Virtual controller 6.5.4.4
    I have deny inter user bridging disabled and my broadcast filtering is set to all.
  • 2.  RE: Client communication between APs
    Posted Sep 12, 2018 08:51 PM
    Change broadcast filtering to "none".
  • 3.  RE: Client communication between APs
    Posted Sep 12, 2018 09:22 PM
    I tried that, but it doesn't seem to help. Is there another place to change this other than in the WLAN settings? I don't see one anywhere.
  • 4.  RE: Client communication between APs
    Posted Sep 12, 2018 09:34 PM
    Are the clients on the same layer 2 VLAN as the printers?
  • 5.  RE: Client communication between APs
    Posted Sep 12, 2018 10:02 PM
    Yeah... As long as everything is connected to the same access point it works perfect. There’s just a couple sets that sit right on the brink of two different ap’s and if the ipad is on one ap and the printer on the other, then ipad doesn’t find the printer
  • 6.  RE: Client communication between APs
    Posted Sep 12, 2018 10:08 PM
    What mechanism does the ipad use to find the printer?
  • 7.  RE: Client communication between APs
    Posted Sep 12, 2018 10:25 PM
    I assume it connects using airprint. But it’s actually an app Planning Center Check-ins that connects to and prints to the printer.
  • 8.  RE: Client communication between APs
    Posted Sep 12, 2018 10:28 PM
    Does the client have any problems pinging the printer when it is on a different access point?
  • 9.  RE: Client communication between APs
    Posted Sep 12, 2018 10:44 PM
    yes, pinging does not work across APs
  • 10.  RE: Client communication between APs
    Posted Sep 12, 2018 10:52 PM
    I don't understand.  Can you ping the printer when the client is on one access point and the printer is on another access point?  Is the printer wireless?
  • 11.  RE: Client communication between APs
    Posted Sep 12, 2018 10:56 PM
    To be clear; if pinging of the devices is not successful, we need to understand why that happens first.
  • 12.  RE: Client communication between APs
    Posted Sep 12, 2018 11:04 PM
    I cannot ping the printer when it is on another AP. The printer is wireless.
  • 13.  RE: Client communication between APs
    Posted Sep 12, 2018 11:06 PM
    Ok.  Is the printer in the same layer 2 subnet? If that is the case, we need to figure that out,first...
  • 14.  RE: Client communication between APs
    Posted Sep 12, 2018 11:14 PM
    yes it is.
  • 15.  RE: Client communication between APs
    Posted Sep 13, 2018 06:12 AM
    Do you have any ACLs on your WLAN between clients?  By default there should not be anything blocking that traffic.
  • 16.  RE: Client communication between APs
    Posted Sep 13, 2018 12:06 PM
    No everything is open within the subnet.
  • 17.  RE: Client communication between APs
    Posted Sep 13, 2018 12:40 PM
    That is unusual.  I would open a TAC case, if you could.
  • 18.  RE: Client communication between APs
    Posted Sep 13, 2018 12:56 PM
    Can do, thanks for the help.
  • 19.  RE: Client communication between APs
    Posted Nov 26, 2020 10:03 AM
    HI, I have the same problem, how did you solve it?
    Mauro Failla
