Regular Contributor I
Client disconnects randomly
Hi i have an issue where some users get disconnected randomly even when not roaming.
i get this message while debugging the users, can anyone tell me what it means?
Ricky E. Lee
CWNA | ACMP | ACCP
Re: Client disconnects randomly
and here is the trail-info.
(DPPSMWC01-B1-GF-SR) #show ap client trail-info 48:13:7e:2d:30:01
Client Trail Info
MAC                BSSID              ESSID            AP-name                      VLAN  Deauth Reason                 Alert
48:13:7e:2d:30:01  44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  STA has roamed to another AP  STA has roamed to another AP
Deauth Reason
Reason                                            Timestamp
STA has roamed to another AP                      Jan 31 16:41:39
Requested authentication algorithm not supported  Jan 31 16:40:46
Sapcp Ageout (internal ageout)                    Jan 31 16:40:10
Requested authentication algorithm not supported  Jan 31 16:33:51
Requested authentication algorithm not supported  Jan 31 16:33:28
Requested authentication algorithm not supported  Jan 31 16:33:06
Requested authentication algorithm not supported  Jan 31 16:32:43
Requested authentication algorithm not supported  Jan 31 16:32:30
Sapcp Ageout (internal ageout)                    Jan 31 16:30:12
Num Deauths:10
Alerts
Reason                        Timestamp
STA has roamed to another AP  Jan 31 16:46:41
STA has roamed to another AP  Jan 31 16:46:30
STA has roamed to another AP  Jan 31 16:46:01
STA has roamed to another AP  Jan 31 16:45:49
STA has roamed to another AP  Jan 31 16:44:07
STA has roamed to another AP  Jan 31 16:43:57
STA has roamed to another AP  Jan 31 16:41:26
STA has roamed to another AP  Jan 31 16:40:59
STA has roamed to another AP  Jan 31 16:40:46
STA has roamed to another AP  Jan 31 16:40:31
Num Alerts:10
Mobility Trail
BSSID              ESSID            AP-name                      VLAN  Timestamp
44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  Jan 31 16:46:41
44:48:c1:08:b0:00  Courtyard_GUEST  DPSSMAP03-BASEMENT-BOH-ENG   1000  Jan 31 16:46:41
44:48:c1:08:b0:00  Courtyard_GUEST  DPSSMAP03-BASEMENT-BOH-ENG   1000  Jan 31 16:46:30
44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  Jan 31 16:46:30
44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  Jan 31 16:46:01
20:a6:cd:fe:86:a0  Courtyard_GUEST  DPSSMAP01-GF-B1-LOBBY1       1000  Jan 31 16:46:01
20:a6:cd:fe:86:a0  Courtyard_GUEST  DPSSMAP01-GF-B1-LOBBY1       1000  Jan 31 16:45:49
Num Mobility Trails:10
Ricky E. Lee
CWNA | ACMP | ACCP
What kind of device is this?
What Operating System Version?
What encryption if any is being used?
Hi Colin,
the one being debug is an android but customer also report seeing this behaviour in apple devices.
ArubaOS ver 6.5.2.1, i will suggest them to upgrade if we cannot make any sense from the log.
open encryption.
Ricky E. Lee
CWNA | ACMP | ACCP
Is the client using 20/40 or 80 mhz channels?
Do they have "Drop Broadcast and Multicast" enabled on all of their Virtual APS?
all 20. i turned off all channel bonding.
"Dynamic Multicast Optimization", "Drop Broadcast and Unknown Multicast", and "Convert broadcast arp to unicast" are all enabled
Ricky E. Lee
CWNA | ACMP | ACCP
What is the ARM Min/Max transmit power configured?
5GHz at 12 to 18
2.4GHz at 9 to 15
Ricky E. Lee
CWNA | ACMP | ACCP
You should enable user debugging to see why your clients disconnect.
EDIT: You already did that..
Looking at the debug, it says that your client just ages out (does not respond).  You should open a TAC case so that they can gather more detailed information.
alright i'll do that.
also, they are using RAP bridge mode, does that affect the client connection and roaming quality?
Ricky E. Lee
CWNA | ACMP | ACCP
