Contributor I
Client load balancing
What happened to the high and low water mark used the balance clients between AP's?  Did SLB take the place of it?  I'm trying to balance b radio clients between AP's.  I work at a hospital and lot of the devices are still only b capable.
Re: Client load balancing
Correct.  That has been replaced by spectrum load balancing.
