Contributor I
Client match for warehousing and barcode collector
Hi Guys,
For a traditional warehouse deployment using IAP 105, how is the best Client match configuration?
The barcode collectors are 2.4Ghz. The AP are well distributed to cover the whole area.
In your opinion, how is the best config for Client match:
CM calculating interval:
CM neighbor matching %:
CM threshold:
SLB mode:
My biggest question is SLB mode, but if have others confs, please feel free to opine...
I'm using IAP with 4.0.0.6 SW
Paulo Raponi
Aruba
Re: Client match for warehousing and barcode collector
I would say to leave it on the defaults.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
Contributor I
Hi Michael,
Thank you... And about SLB mode? Let "Channel" ?
