Frequent Contributor II
Client roaming from 802.11g to 802.11n AP
from your experience can a Wi-Fi client have connection/disconnection issues when roaming from a 802.11g Access Point (AP60) to a 802.11n AP (AP93)?
Massimo
Massimo Gallina
Telecommunications engineer - ACMP2013
Re: Client roaming from 802.11g to 802.11n AP
Yes , since the client might see the 802.11n AP a better connection (MIMO) even when its closer to the 11g AP and the client may not roam to the 802.11g (sticky client).
Thank you
Victor Fabian
Lead Mobility Architect @WEI
So to avoid this problem, do I just have to disable the 802.11n from AP93?
Massimo Gallina
You could take that route but Its your environment completely mixed of 11n and 11g APs , are those very close to each other? or it just a one off situation ?
Thank you
Victor Fabian
It's an old big environment where we at first have only AP60/61; then when the customer was in need of additional APs we have provided him AP93. The actual situation is that we have more or less 1 AP93 every 10 AP60/61.
In your opinion what is the better solution?
Massimo Gallina
In that case you might as well turn off 11n since you have way more 11g APs in your environment and once you are able to have better 11n footprint to turn it back on
Thank you
Victor Fabian
Thank you very much for your useful suggestions Victor!
I will apply in the next days these configuration changes.
Massimo Gallina
