Occasional Contributor I
Client total connection time
Good Morning all
We have 7210 controller - OS 6.3.1.21, 278 AP225s, CPPM 6.6
I have been asked by my supervisor for "total connection time" per user or client device.
Is there a way from the information on gui for the controller to find this out?
Any one know a CLI command for controller or CP to get this?
Is there a report in CP that can generate this information ?
Thank you in advance for your time and attention
Re: Client total connection time
Do you have AirWave?
Tim Cappalli | Aruba Security
Yes
Take a look at the client session report. You can also customize and create your own reports.
