ClientMatch Issue
Hi folks,
i have the Sticky client issue in a WLAN , and i'm using 6.4 firmware, so my question si :
 do client match works with all AP or with new Generation AP2XX only.
Regards.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Client Much
ClientMatch works with 11n and 11ac access points.
Tim Cappalli | Aruba Security
Re: Client Much
and in the two band (2.4 and 5 Ghz)
Raouf CHAHBOUNE
Re: Client Much
Yes
Re: Client Much
If your AP power is too high, (more than 18dbm), Clientmatch will probably not help, because your clients will continue to hang onto the same AP.  If you have not done so, please try to constrain your MIN TX to 12 and your max tx to 18 in your ARM profile.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
